Fixing Droopy Bumpers (I Hope!)
Postby jclay (RIP 2018) » 22 Feb 2011 00:06
Well here is my idea, but it has not been proven yet. When it stops raining!
http://web.me.com/jclaythompson/Technical/Droopy_Bumpers.html
[url="http://web.mac.com/jclaythompson/Site/Welcome.html"]My Triumph Site[/url], [url="http://web.me.com/jclaythompson/Technical"]Technical Stuff[/url], [url="https://docs.google.com/?hl=en&tab=wo&authuser=0&pli=1#all"]Download Page[/url]
prlee
Postby prlee » 22 Feb 2011 19:11
Should work fine.
You may only need 2 screws at the top. The design stills allows some vibration absorbtion because it doesnt use freeze up the bottom of the mount which usually stays intact. You could also use something like loctite 601 or 638 to lock the screws in place.
I have the welded version from S&S on my DHC.
Pete
81 Red DHC
79 Blue Spitfire
Image ImageImage
tr7jim
Postby tr7jim » 23 Feb 2011 17:10
jclay,
On my previous dhc the bumper bracket were welded as per S&S so making them fixed but I was thinking along the same line has yourself but with using counter sunk screws / tapping out a screw thread etc.
The only comment maybe is wouln't it be better having two screws on the top edge and one on the bottom edge in a triangle pattern, so holding the bracket plates parrellel & straight.
But do like the idea and will work with the unscrewed edge been in compression with the weight of the bumper.
Jim
Users browsing this forum: No registered users and 230 guests
