Zenith Stromberg adjusting tool
Postby REPLIC8 » 05 Dec 2010 15:57
My TR8 is running very rich according to the black sparkplugs, I've bought an adjusting tool for the Stromberg carbs with the intention of investing in a gas analiser to get the emmissions correct. However I've tried inserting it in the top of the dashpots & it doesn't appear to go in far enough to engage either part of the tool. I don't want to push it to hard in case I damage something. I've posted a photo of the tool, is this the correct one? If so what am I doing wrong?
[img][IMG]http://i473.photobucket.com/albums/rr92/REPLIC8-2008/small_140.jpg[/img][/img]
Gubi
Postby Gubi » 05 Dec 2010 16:00
You need to slide down that little rubber stop on the hex shaft a bit. Push it down until you can get both parts of the tool to engage.
Tom
'79 TR7
'87 Alfa 75
'91 Alfa Spider
Postby REPLIC8 » 05 Dec 2010 16:46
OK, I've got the top part of the tool to slide down & engage but The hex key part doesn't appear to engage into anything positively. If it's where it should be will there be any turning resistance? Mine spins round with the slightest touch.
Postby john 215 » 05 Dec 2010 17:29
Hi Andy,
Are you sure your diaphrams are not split, a common fault on these.
Postby REPLIC8 » 05 Dec 2010 18:09
John,
Quite possible, most things I look at tend to be broken at the moment.[:D][:D]
Would this cause it to run very rich? I did have it set once when I first got the car but it was back running rich again at the MOT a few weeks later. Would that be why there is no turning resistance on the hex key?
slider
Postby slider » 05 Dec 2010 20:05
put some SU's on they are a far superior carb to MY mind and i had mine set up with a vacume set-up kit, no probs at all(runs spot on), oh ! mine are manual choke![:D]
RadioGuy
Postby RadioGuy » 05 Dec 2010 20:07
Take the air filter off and look at the air valve while giving the engine some gas/petrol. The piston/air valve should move up. If it does then the diaphragm is not split enough to cause what you are experiencing.
If it does go up when the engine is revved then the hex tool may not be engaged/inserted into the adjustment slug, you should be able to feel the hex tool seat into the slug.
The pin might be missing from the piston/air valve.[:0]
May be time for a rebuild. Not expensive and a good learning experience. Do both...one at a time of coarse the first time. [:D]
Postby john 215 » 05 Dec 2010 20:44
Hi Andy
Does not tend to cause a rich mixture, but the engine good as ends up running on a single carb. IF you take of the tops of the carbs and may be a good idea so you set both needle at the same hight and check to make sure nothing horrible has happened to your carbs in the past then order a couple of diaphrams and change.
Have you FASD on your carbs [?]
Postby REPLIC8 » 05 Dec 2010 21:37
They're manual choke, which appears to be working fine. I did find a couple of needles in the glove box so they've been changed at some point. Might take the tops off & have a peak inside. At least then I'll be able to see where the hex key should be locating. Carbs are still a bit of a mystery to me.
Postby jclay (RIP 2018) » 05 Dec 2010 21:45
zenith stromberg tech tips http://home.att.net/~allens_gifts/zenithstromberg.htm
Preamble
This article, with many, many more lies within the pages of the University Motors Technical
Book. This book is being revised for the 1997 Technical Seminars and will be available in
January, 1997. Please write then if you would like a copy. This article (as others) is copywritten
but you have MY permission to reprint it in any publication, as long as my name John Twist, and
that of University Motors, appears at the end of the text. Give credit where credit is due!
THOSE DARN ZENITH STROMBERGS
By John H. Twist
The carb illustrated is a
slightly modified version from
that of the MGB, but will give
you a good idea of how things
are put together.
Introduction
The Home model MGBs and Midgets were not plagued with this Triumph inspired imitation SU,
we are. The Home and most export model MGBs (except North America) continued to use twin
HIF4 carbs, the Midgets, HS4s on the Triumph 1500 engine, while the Canadian, Federal, and
California specification MGs were fitted with the Stromberg. Emission specifications were cited
as reasons to move to one carb (more easily kept in tune than two carbs), but why not choose the
HIF6? Despite all the assurances of the manufacturer that this single carb could lessen emissions,
the Zenith often runs dramatically rich.
When the carburetor does run extremely rich, and if the emission control system (air pump and
2 of 5 4/8/2004 1:00 AM
catalytic converter) is still in place, then the converter will glow cherry red hot. This carburetor is
responsible for hundreds of underbonnet fires! Yet, with a little regular maintenance, this carb
will perform correctly and safely, while offering relatively high mileage compared to the twin
SUs.
Adjusting the Carburetor
To properly tune the Stromberg, one must have the Stromberg adjusting tool (a 1/8" allen wrench
within a pinned tube), a 10mm long open end wrench, a small screwdriver, and a medium
screwdriver. A tach/dwell is always most helpful.
The engine is started from cold, and the spring loaded idle screw is adjusted until the engine is
running at 1800 rpms maximum. One the engine has fully heated and the engine dropped to its
lowest rpm (choke all the way off), then the locknut screw (hence the 10mm wrench) is adjusted
until the engine is idling at about 850-900 rpms. All further adjustments to idle speed will be
made again with the spring loaded screw.
Now the mixture is adjusted. Lift the air piston ever so slightly and judge the change in rpm. If
the idle speed continues to rise as the piston is lifted, the mixture is too rich. Turn the allen
wrench anti clockwise to lean it out. If, on the other hand, the idle speed slows or stumbles when
the piston is slightly lifted, then the mixture is too lean. Turn the allen wrench clockwise to
richen it. A proper idle mixture allows the rpm of the engine to rise and steady, or rise and slowly
fall off as the piston is slightly lifted. As the correct mixture is reached, the idle speed will rise,
and several adjustments may be necessary to hold the idle at that 850-900 figure. Be certain to
rev up the engine, to clear it out, between each adjustment.
When adjusting the carb at home, tighten the air bleed screw (MGB) so that no air passes through
this circuit.
Running Rich
The most common complaint is that no matter how many turns anti-clockwise the allen wrench is
screwed, the mixture is still far too rich. There are five major areas of concern:
1.The air cleaner is filthy and sooted. This is not uncommon, and any leaks in the
manifold/exhaust, especially a cracked exhaust manifold, will soot up a new air cleaner in no
time. This causes a much higher vacuum in the venture, and more gasoline is drawn into the air
stream.
2.The ELC system is pressurized. This is very uncommon, but easily checked. Remove the
vapour line, the vent line, the overflow line from the carburetor. This line travels across the valve
cover on the MGB to the charcoal adsorption canister, or directly to the canister on the Midget.
There should be NO CHANGE in the idling or operation of the engine. If there is any change,
then the ELC system needs to be cleaned, and checked for blockages. It is far more common for
this system to develop a vacuum which creates a lean running condition, in fact the primary
reason for lean operation!
3.The automatic choke is the most common cause of rich running. These problems are:
The choke assy has come loose from the body of the carb. The vacuum from the carburetor then
draws fuel from the float bowl around the valve which should is closed during warm running.
Simply tightening the three slotted copper coloured screws eliminates this as a problem.
The choke lever and cam have stuck in a part- open position. A good tune-up requires that the
3 of 5 4/8/2004 1:00 AM
choke assembly be removed from the carb, that it be well cleaned in spray carb cleaner, the pin
nut tightened, and the unit well lubricated.
The bi-metal spring in the heat mass is not correctly calibrated. Simply place the heat mass in a
pan of boiling water, and wait for the bi-metal spring to rotate clockwise to its fullest extent. The
notch on the bi-metal spring should be in line with the mark on the aluminum housing. If it does
not line up, then scribe a new mark with a hacksaw blade. The line on the heat mass, on the black
plastic insulator, and the choke body should all be in line.
The small passageway from the carb throat (past the butterfly) to the top of the auto choke assy
allows vacuum to pull off the spring loaded enrichment plunger. When this passageway fills with
soot (as it does after years of running), this plunger remains seated, holding the choke ON. By
cleaning this passageway with a small wire, the vacuum can take its proper route.
The mating flange of the auto choke can become warped and allow petrol to by-pass the choke
valve. SURFACE this mating flange on a smooth block with fine grit paper and thoroughly clean
after the surface is smooth.
Only several times have we encountered a choke assembly whose brass choke valve was not fully
inserted into the housing, so that even when the choke pin was moved fully downwards, it was
not seated in (and therefore not closing off) the choke.; This condition can be positively
determined by removing the automatic choke and covering the screw holes and fuel passageways
with a piece of masking tape, then checking the mixture again.
4.Should the rubber diaphragm in the carburetor tear or perforate, then the engine will run very,
very rich, and the maximum speed of the MG will be limited, until, at last, it can travel only ten
or fifteen miles per hour, all the while spewing forth incredible clouds of black, sooty,
uncombusted exhaust. A torn diaphragm is easily found by removing the top of the suction
chamber (four phillips screws).
While the diaphragm is being inspected, pay attention to the following.
5.Rarely does a needle disassemble itself, but it does happen. The metering needle is held in a
small barrel against spring force by a very small pin. If this pin breaks, the needle pops upwards
by 1/8" or so, and no amount of adjusting can correct for such a gross misplacement of the
needle. The shoulder of the needle can always be seen on the underside of the air piston. If it has
slipped up inside, and the metering needle has a lot of up and down (against the spring)
movement, then the pin should be check and replaced (paperclip works wonderfully).
Running Lean
A leanness at road speed is often described as a hesitation, as if a wind was blowing against the
car. This can be caused by retarded timing or not enough gasoline in the air/fuel mixture. There
are several possibilities for a lean running condition:
1.The ELC System (Evaporative Loss Control) is plugged which can place a vacuum above the
gasoline in the float bowl. As noted above, remove the vent line from the carb and note any
change. A plugged charcoal adsorption canister (from dirt or from a previous overflowing
carburetor condition), or a plugged vent line from the bottom of the anti- run on valve are the
most common problems.
2.The float height is set far too low.
3.The air cleaner is not fitted to the carburetor. as unusual as this seems, and for reasons that are
4 of 5 4/8/2004 1:00 AM
unclear to this author, the Stromberg carburetted MGB will not run with the air cleaner removed
(or a vanity air filter to replace the original). Oh, it will get to 2500 rpms or so, but then flattens
out -- no good for any kind of driving.
Carb Will Not Idle Down
Sometimes the carb will not idle at lower than 1000 or 1200 rpms. This is almost always a
mechanical problem, but the possibilities include:
1.Throttle cable is stiff or incorrectly adjusted. Leave this cable loose until the carb is completely
adjusted, THEN tighten the two nuts with 7/16" wrenches.
2.The cam within the automatic choke is not returning to a "full off" position, sometimes caused
by a melted plastic plunger on the bottomside of the unit. Melted? Remember that cherry red hot
catalytic converter? Sometimes the levers are bent. They all work on nice, sharp, 90 degree
angles.
3.The overrun valve is floating open at a very low manifold depression. The spring loaded valve
on the throttle disc is designed to open only at extreme manifold vacuum -- deceleration. If there
has been a fire within the carburetor, the spring may have lost its force. The valve is easily
soldered shut obviating any further problem (and increasing throttle deceleration response). Heat
the valve from the button side with a propane torch and flow solder into the valve from the spring
side. The Midget overrun valve can be completely shut off by fully unscrewing the small slotted
screw on the triangular shaped device on the right side of the carb.
Air Leaks at Idle
Any tuning or mixture adjustment is impossible if there are air leaks between the carburetor and
the cylinder head. This is a very common occurrence, unfortunately, but the leaks are easily
identified. With a can of aerosol carburetor cleaner, spray into areas where leaks are found while
the engine is idling. If there is an air leak, the rpms will rise or fall (depending on the size of the
leak, the adjustment of the carb, and the type of aerosol spray). Areas the leaks most commonly
occur are:
1.Between the cylinder head and the intake manifold, most commonly at the 1/2 intake port.
2.The tubing and fittings associated with the smog pump (gulp valve, line from the valve to the
90 degree fitting, and the 90 degree fitting itself).
3.The EGR (Exhaust Gas Recirculation) Valve located right on top of the intake manifold
between the brake master cylinder and brake booster.
Any leak MUST be corrected before tuning commences.
Other Common Problems
Oil in the dashpot is essential for proper operation! If there is no oil the engine will start with
difficulty and will not accelerate quickly. Use ENGINE OIL, and do not worry, the dashpot
(despite warnings to the contrary) cannot be overfilled. If the oil disappears too frequently, then
the O ring must be changed. A need for oil more than once per fill-up would certainly be
aggravating.
The screws holding the heat mass to the choke assy are stripped and the heat mass will not keep a
proper alignment. The holes in the choke housing can be tapped out to 10-32.
5 of 5 4/8/2004 1:00 AM
The screws fixing the top of the suction chamber to the carb body are frozen tight. They can be
freed by using vise- grips for the first 1/10th turn (then use the screwdriver), or smack the end of
the phillips (posi-drive) screwdriver with a hammer to seat the end of the screwdriver and shock
the threads loose. Use new 10-32 screws when reassembling.
The carburetor heater is cracked, broken, or not connected. There is no concern here. Everything
works just fine without this piece of emission control.
A last warning. Do not spray carburetor cleaner down the throat of the carb.The aerosol will
attack and expand the rubber diaphragm. Be safe -- carry an extra diaphragm!
The Zenith Stromberg carburetor will work wonderfully well on your MGB or Midget -- if you
keep it clean, oiled, and adjusted.Refer to your workshop manual for more details, and work with
it BEFORE buying some foreign carb to replace it. Remember, if MGs were meant to have
Webers, Kimber would have made a deal with Mussolini.
Please remember: This article was written by By John H. Twist of University Motors.
Return to my 1978 MGB Page
[url="http://web.mac.com/jclaythompson/Site/Welcome.html"]My Triumph Site[/url], [url="http://web.me.com/jclaythompson/Technical"]Technical Stuff[/url], [url="https://docs.google.com/?hl=en&tab=wo&authuser=0&pli=1#folders/folder.0.0B6b9tx6hnkzLYzM5MmNhYWItZjliYS00M2QzLWE1M2YtNWNlZWIzZjExZTdm"]Download Page[/url]
Postby Workshop Help » 05 Dec 2010 23:55
Gentle Men, AHEM!!!
Our wonderful Z-S carburetors will produce an over rich mixture when the FLOAT LEVEL is improperly set, or there is EXCESS FUEL PUMP PRESSURE. I have experienced and fixed both conditions.
1. Are you running the stock mechanical fuel pump? It should be providing about 2 lbs of pressure and no more. Excess pump pressure will overwhelm the float needle(s) with whole buckets of gasoline hosing up into your cylinders. A $30.00US adjustable fuel regulator set at 2 lbs will remedy an over eager fuel pump. This is a VERY common problem when using an aftermarket electric fuel pump. I just went thru this little nightmare on Thursday.
2. The float levels must be confirmed to be at the factory setting of about 5/8". Any deviation will result in either a too rich or a fuel starvation condition at higher engine speeds. Also, but not all that common, can be a leaking float which allows excess fuel into the float bowl.
3. Yes, this is the correct tool to set the mixtures on a Z/S carburetor, however before using it, attend to the above listed basics. Do you have the correct workshop manual for your engine? It should have a section devoted to the servicing of the carburetion. While an exhaust gas analyzer would be a wonderful XMAS present from Santa Claus, a cheap vacuum gauge and your learning to read and interpret your spark plugs will do you much good. We do have a listing for the web site for spark plug reading. Use the SEARCH function to locate it.
Postby DNK » 06 Dec 2010 20:59
The stock TR8 had a mechanical pump.
I didn't know that. Thought all were electric
"No More Cars For You"
71 TR6- Perpetual remodel
ColoradoTR8
Postby ColoradoTR8 » 06 Dec 2010 21:45
TR8's were all electric. The carb cars have a low pressure pump inside the fuel tank, the FI cars have high pressure pump outside the tank.
I've had several of those $30 dial type regulators fall apart in my hands. Straight out of the package. Had even more not provide the pressure that they indicate on the dial. Not sure I would trust one.
<b><i>Shawn</i></b>
Postby DNK » 06 Dec 2010 22:07
Shawn, Thought there was no mechanical on an 8. Did any of the early 7's have a side mounted mechanical?
Postby REPLIC8 » 08 Dec 2010 10:16
Today I dismantled the carb tops and discovered the following.
The diaphragms are fine, one of the needles was detatched from the adjuster, but the strange thing is the reason my adjusting tool does not locate is because the adjuster inside the piston assembly doesn't have a hex key fitting, I removed the adjuster (don't know if I should have done that or not?) and took the following picture. Is this the wrong part? Can I get a different tool to adjust this or do I need to get a new correct piston assembly?
UPDATE: I've since discovered this is an alternative version for which there is a specific adjusting tool. I've ordered one of those together with 2 new adjusters & retaining rings. May as well put it back together with nice new bits. Then I'll have a go at setting it up usings Jclay's instructions. [:)]
[img][IMG]http://i473.photobucket.com/albums/rr92/REPLIC8-2008/small_PC080660.jpg[/img][/img]
Users browsing this forum: No registered users and 171 guests
