Inlet manifold leak
macmattom
Inlet manifold leak
Postby macmattom » 09 Nov 2010 12:34
<font face="Comic Sans MS"><font size="2"><font color="blue">Hi again. I have just refitted my new water pump, and put the inlet manifold back on. The water pump appears water tight at the moment, but as soon as I pour water into the thermostat it runs out of the head.
The water runs out from directly below the forward-most of the 6 bolts holding the manifold to the head, the one located forward of the front inlet tube but rear of the water pipe. The best option for me would be if you can buy thinner inlet manifold gaskets (mine is about 1 mm or 40 thou (by eye!)) or a thicker O ring seal. Does anybody know if this is the case, or might it be more sinister. Worst case for me would be a warped head (but I haven't heard of them warping there before) or a warped/dirstorted manifold.
Could anybody give any suggestions as to what might be a cause and solution? I'm really hoping to get the car running shortly, but this is not helping my cause. Below are a few photos to identify the bolt in question - it's the bolt without the circular recess. It has been helicoiled once before, but I can't imagine that would have gone through into a water channel!
Thanks very much,
Mac.
Image </font id="blue">
</font id="size2"></font id="Comic Sans MS">
bahbzilla
Postby bahbzilla » 09 Nov 2010 14:29
Is it possible that it is leaking from the water pipe connection and running down so it appears to be coming from that front bolt? When I put my intake manifold back on, I put some silicone on the o-ring to hold it in place while moving things around and to improve the seal.
1980 TR7 DHC
Postby FI Spyder » 09 Nov 2010 14:49
I too would firstly suspect the O ring. I believe jclay uses three evenly spaced dabs of crazy glue to hold it in place as it can easily fall/get moved out of position as you put the maniflod back on. I suppose you shouldn't assume the O ring was the right size (thickness wise) as assumptions can lead you down the garden path but its position shifting is most common problem.
Postby Beans » 09 Nov 2010 17:23
<blockquote id="quote"><font size="1" face="Century Gothic, Verdana, Arial, Helvetica" id="quote">quote:<hr height="1" noshade id="quote"><i>Originally posted by macmattom</i>
... Could anybody give any suggestions as to what might be a cause and solution? ... <hr height="1" noshade id="quote"></font id="quote"></blockquote id="quote">
Looks like I had the same problem recently, covered it in my weblog ...
http://tr7beans.blogspot.com/2010/09/water-pump-here-we-go-again.html
Bobbieslandy
Postby Bobbieslandy » 09 Nov 2010 19:50
i had a similar problem, the metal pipe had shifted too far into the manifold so the lower O ring wasnt' actually sealing. i got a pair of slim grips on that small metal pipe and moved it down until it stopped leaking. Actually it may of needed moving up, i can't remember. Either way it's possible to manipulate that pipe until the leak stops.
Rob.
Postby John Clancy » 10 Nov 2010 08:56
Or the inlet manifold gasket is on the wrong way. Very easily done and it means a waterway is not blocked off correctly causing the cooland to pour straight out.
Good luck. It's bound to be something trivial.
RadioGuy
Postby RadioGuy » 10 Nov 2010 09:08
<blockquote id="quote"><font size="1" face="Century Gothic, Verdana, Arial, Helvetica" id="quote">quote:<hr height="1" noshade id="quote"><i>Originally posted by John Clancy</i>
Or the inlet manifold gasket is on the wrong way. Very easily done and it means a waterway is not blocked off correctly causing the coolant to pour straight out. <hr height="1" noshade id="quote"></font id="quote"></blockquote id="quote">
John' right I did that once. Took a lot of cussin and figuring to get it fixed.[B)]
macmattom
Postby macmattom » 11 Nov 2010 22:04
<font face="Comic Sans MS"><font size="2"><font color="blue">Well, many thanks to all of you. I reckon I know where it's gone wrong - and I feel like such a plonker! I never considered the gasket being able to go on backwards, but John Clancy's suggestion and Beans's blog prove to me I've been putting the gasket on the wrong way round [:I]. I might also take the belt and braces option and use 2 O rings, one fitted inside the other (again, inspired by Beans's blog - double thanks [:)]). I won't get back to the car for a week, but when I do I'll let you know how it goes.
Thanks again,</font id="blue"></font id="size2"></font id="Comic Sans MS">
Postby nick » 14 Nov 2010 16:41
Nice looking chromed parts.
'79 TR7
macmattom
Postby macmattom » 14 Nov 2010 18:35
<font face="Comic Sans MS"><font size="2"><font color="blue">Thanks, Nick. I just hope they stay that way!</font id="blue"></font id="size2"></font id="Comic Sans MS">
Postby Beans » 14 Nov 2010 19:26
... hope they stay that way ... <hr height="1" noshade id="quote"></font id="quote"></blockquote id="quote">
Prepare for regular polishing [:p]
Users browsing this forum: No registered users and 281 guests
