What is this wire for?
Postby UKPhilTR7 » 27 Oct 2010 19:32
Under my drivers seat I have two wires coming from the seat, with two connectors on each wire. The one wire goes to the fasten seat light on the dash, but I have no idea where the other one goes. Does anyone knwow what the other wire is for?
Postby stevie_a » 27 Oct 2010 19:39
<font color="teal"><b>It is for the seat belt warning light
To remind you to fasten up
Mine is disconnected....[:I]</b></font id="teal">
Postby UKPhilTR7 » 27 Oct 2010 19:43
Hi Steve, that is the one that I have got connected and it shows on the dash, but there is another one that I have no idea wat it is for.
Postby busheytrader » 27 Oct 2010 19:52
Maybe your driver's seat was once on the passenger's side? If so the wires could be from the pressure sensor.
It is possible to swap the seats over but the reclining lever will be nudging the transmission tunnel if left unchanged.
TR7 V8 DHC Jaguar Solent Blue. 9.35cr Range Rover V8, Holley 390cfm, JWR Dual Port, 214 Cam, Lumention, Tubular Manifolds, S/S Single Pipe Exh, 3.08 Rear, 200lb Spax & PolyBushes all round, Anti- Dive, Strut-Top Roller Bearings, Capri Vented Discs & Calipers, Braided Hoses, 4 Speed Rear Cylinders, Uprated Master Cylinder & Servo, AT 14" 5 Spokes or Maestro Turbo 15" Alloys, Cruise Lights, S/S Heater Pipes, Replacement Fuel Tank. No Door Stickers. Mine since July 1986, V8 from 1991
Postby DNK » 27 Oct 2010 20:04
Was there ever a buzzer on these?
"No More Cars For You"
71 TR6- Perpetual remodel
elsberry
Postby elsberry » 27 Oct 2010 20:27
It's a long shot, but mine has both on the drivers side. One for the seat belt, one for the pressure switch, but it's a US build. Perhaps that was an 'added feature' [;)]
Dave Elsberry
1980 US spec DHC
1974 Jaguar SIII XKE
1994 Jaguar XJ12
I need more garage space!
[url="https://docs.google.com/leaf?id=0B26QZc97k0noYTAxMzUxZjgtMzZkZS00MWEwLWEyZmYtOWRkMzliNWZhMDA3&hl=en"]My Triumph Document Repository[/url]
Postby FI Spyder » 27 Oct 2010 20:57
Yes there is. Mine works perfectly. It's a pain in the butt sometimes (so to speak).
Postby UKPhilTR7 » 28 Oct 2010 12:58
Well I never know that. So if that is the case, where should the wire go into as I only have the one wire coming to the seat, the one for the dash light.
prlee
Postby prlee » 28 Oct 2010 19:54
Divers side should only connect to the seat belt. Passenger has the pressure pad as well.
However my car is like yours and had a pressure pad on the driverside as well, but it isnt used and I have have removed mine.
Logically there will always be a driver so no need for the pressure pad.
Pete
81 DHC Back on the road and running in
79 Spitfire (big hole in the floor)
Image ImageImage
Postby bmcecosse » 28 Oct 2010 20:51
Mine had pads on both seats too, long since discarded - all part of the general 'wasteful' approach at Leyland - no wonder they lost money on every car. It would be just too difficult to specify pads on LH seats for RHD cars - and pads on RH seats for LHD cars........
Users browsing this forum: No registered users and 187 guests
