Fitting Radio
The Old One
Fitting Radio
Postby The Old One » 24 Oct 2010 17:27
Hi All
My DHC did not come with a radio so my son has given
me a ripspeed one which has a multi connector on it.
It has the wiring details on it but i am no electrician.
So could someone tell me which way i should do it.
There is a yellow wire to connect to battery and a red
wire to connect to aux. What colour wires on the car
should i connect into.I have found the original speaker wires
which are ok.
Postby nervousnewowner » 24 Oct 2010 18:04
would of thought red to switched and fused live through ignition switch, black to earth and yellow should go to a constant live somewhere such as the clock to store radio stations etc when stereo is knocked off, speakers should be solid colour live side mixed to negative? would guess the multi plug would have a blue somewhere for connecting an electric ariel? [:D]
am sure i will be corrected if i'm wrong, hopefully before you set fire to the car and blame me..........[B)]
Postby DNK » 24 Oct 2010 18:05
Depends on what you want to do with it ans when you want to be able to use it.
Key off or on type of thing.
If this is a new radio they are a lot more powerful than old ones so running them with the key off could build up a lot of heat on our little wires
"No More Cars For You"
71 TR6- Perpetual remodel
Postby nervousnewowner » 24 Oct 2010 18:08
and the 6x9s on each side of the hood on coathangers and the 14inch sub in the spare wheel well..........
sorry got 22yr old twins who keep telling me how to "improve" my car, apparently knight rider scrolling red light in bonnet and red lights in the footwells would look "cool" too........[:D]
Postby nervousnewowner » 24 Oct 2010 18:10
good point dnk, leave space next to sub in boot for fire extinguisher......
only kidding, got cd player to go in mine soon as i stop all the leaks,........
Marsu
Postby Marsu » 24 Oct 2010 18:24
[Edit - beaten to it - dawdled too long finding pics [:I]]
I'm not sure what variations may exist in various models, but on mine, a 1978 Speke built FHC for Australian delivery the red wire from the radio connects to a White/Pink cable that is switched by the ignition key. This wire connection emeges from the main harness with the Black/White speaker connection end points. (See pic below)
I did not connect the yellow continuous feed on my car as there is not a connection point for it and I don't mind tuning the radio it each time I use it. If you do want to connect this you will need to either run your own cable to the battery terminal (not recommended) or splice into one of the brown cables that carry live feed.
There are a few locations you could do this. The shortest distance to cable to would be to the butt join in the harness on top of the right hand side of the fuse box. (See pic below)
The Old One
Postby The Old One » 24 Oct 2010 19:07
Thanks All
Will Do It Tomorrow
Do I Have To Put A Inline Fuse In Both Live Feeds
And If So What Size?
Thanks Again
Marsu
Postby Marsu » 24 Oct 2010 19:18
Definitely fit at least 10A inline fuse on the red cable.
I'm not sure on the yellow. I suspect not, but check the radio documentation.
Postby stevie_a » 24 Oct 2010 19:20
<font color="teal"><b>A lot safer and easier to buy one of these</b></font id="teal">
clicky
[url="http://cgi.ebay.co.uk/Test-lamp-circuit-tester-6v-24volt-Cable-piercing-/140466755718?pt=UK_Hand_Tools_Equipment&hash=item20b4789886"]Image[/url]
The Old One
Postby The Old One » 24 Oct 2010 19:37
Thanks stevie a, will order one.
The Old One
Postby The Old One » 25 Oct 2010 19:10
All Fitted & Working Complete With Rear Speakers Also.
Thanks For The Advice
Postby nervousnewowner » 26 Oct 2010 21:17
nice one, happy motoring...[:D]
Users browsing this forum: No registered users and 186 guests
