Here's how the stupid wiper switch spring goes.
Gubi
Postby Gubi » 17 Oct 2010 00:29
From searching it appears I'm not the only one who launched their wiper switch spring across the garage and then couldn't figure out how it went back in. Found one in the junkyard today and the pic below is how it goes. Photo is oriented with the switch right side up as it would be in the car.
The trick is you need to cross the spring onto both sides of the second contact from the bottom. Note that if you remove the arm and spring you need three hands with super strong pencil-thin fingers to get it all back together properly. Ask me how I know.
Anyway, my single wipe functionality works now, so that's good.
Tom
'79 TR7
'87 Alfa 75
'91 Alfa Spider
Postby busheytrader » 18 Oct 2010 08:16
Nice photo there.........
My spring hit me smack in the face when I opened up the switch.
I found foul language a useful substitute for that illusive third hand.
TR7 V8 DHC Jaguar Solent Blue. 9.35cr Range Rover V8, Holley 390cfm, JWR Dual Port, 214 Cam, Lumention, Tubular Manifolds, S/S Single Pipe Exh, 3.08 Rear, 200lb Spax & PolyBushes all round, Anti- Dive, Strut-Top Roller Bearings, Capri Vented Discs & Calipers, Braided Hoses, 4 Speed Rear Cylinders, Uprated Master Cylinder & Servo, AT 14" 5 Spokes or Maestro Turbo 15" Alloys, Cruise Lights, S/S Heater Pipes, Replacement Fuel Tank. No Door Stickers. Mine since July 1986, V8 from 1991
Users browsing this forum: No registered users and 246 guests
