tr7v8
glen oliver
tr7v8
Postby glen oliver » 03 Oct 2010 16:40
the tr lives now just got to sort out why the reversing lights stay on and i have no indicators,i love tr`s,it worked fine before it was layed up ?
Postby Maxwell » 03 Oct 2010 17:33
Hi
Did you lay it up in reverse? I believe the switch is operated by a small ball-bearing like probe on the side of the box. Perhaps it's stayed pushed in...
Indicators? No doubt someone more knowledgeable than me will suggest you check the earthing first!
Maxwell [:)]
3.5 TR7 V8 Drop Head \ Oliver
0.7 Smart Roadster \ Oscar
2.0 TR7 Drop Head - SOLD \ Maxwell
2.0 TR7 Fixed Head - SOLD \ Robyn
Bobbieslandy
Postby Bobbieslandy » 03 Oct 2010 19:11
I got to mine by removing the gearlever gaiter (boot) and removing the metal plate under that. It still wasn't easy but you can disconnect the plug connecting the switch to the loom and see if it's failed, it should be open circuit when not in reverse, or removed.
Just to add, the switch has a lock nut which determines the depth that the switch sits inside the box. if you remove the switch then take care to keep the lock nut in the same position. To set it up, should you of disturbed it then i put the box in reverse (ignition on), had the missus stand at the rear of the car while i screwed the switch in. Once the reversing lights came on then i gave it another full turn and nipped the lock nut up. I'm not entirely sure all switches are the same so a full turn on mine may not be enough or too much for yours. trial and error i reckon!
glen oliver
Postby glen oliver » 04 Oct 2010 22:46
i now have indicators,just the reverse switch to do,then mot again,better late than never lol [8D]
Marsu
Postby Marsu » 04 Oct 2010 23:07
What did you do with indicators?
(mine are being difficult at present)
glen oliver
Postby glen oliver » 05 Oct 2010 22:01
indicators were down to a new flasher unit faulty,changed it,then they worked,did not expect a new bit to not work ?[:D]
glen oliver
could also be down to faulty hazzard switch
Users browsing this forum: No registered users and 245 guests
