Plasticised Stone chip paint
Redwood
Postby Redwood » 01 Oct 2010 11:24
I have a 1980 TR7 which is suffering from flaking of whatever preparation has been applied to the rear sill panels below the rear bumper. It is a thick black application which seems to have a plastic quality. The car has been re-built around 5 years ago. Any ideas on a suitable spray or paint on replacement product?
Regards.
Postby UKPhilTR7 » 01 Oct 2010 11:38
Have a look at the POR-15 rust preventative paint on the Frost website. I have found it great in the past. It is a bit expensive, but you know that it is hard as nails. I have used this paint all over my car and will continue to on the wheel arched back and front. This is much better than the stuff you can get of the shelf.
http://www.frost.co.uk/productList.asp?catID=28&frostCat=Rust&subcatID=37&frostSubCat=POR%2D15
kstrutt1
Postby kstrutt1 » 01 Oct 2010 20:11
It sounds like stone chip paint, you can get it in areosols or 1 litre tins which are applied with a special spray gun, the later gives a thicker more dimpled finish.
Whichever you use you need a sound surface first so all flaking paint and rust needs removing and priming (I like zinc rich paint often described as cold galvanising).
Redwood
Postby Redwood » 04 Oct 2010 13:15
<blockquote id="quote"><font size="1" face="Century Gothic, Verdana, Arial, Helvetica" id="quote">quote:<hr height="1" noshade id="quote"><i>Originally posted by Redwood</i>
Regards.
<hr height="1" noshade id="quote"></font id="quote"></blockquote id="quote">[:)] Many thanks to both UKPhilTR7 and kstrutt1 for your feedback....much appreciated.
Users browsing this forum: No registered users and 251 guests
