TR7 droptop
hymie747
TR7 droptop
Postby hymie747 » 16 Sep 2010 05:24
Just got home the other night and parked the car. nEXT MORNING THE IGNITION LIGHT IS ON AND IT WONT START. Any thoughts?
Postby John Clancy » 16 Sep 2010 08:27
Does it turn over? What other symptoms and information can you give us because I don't think there is anything wrong with the ignition light being on providing you've turned the key. If it's on when you get in the car and ignition hasn't been engaged then clearly something is amiss.
tattytr8
Postby tattytr8 » 16 Sep 2010 09:36
the usual favourite for the igniton light being stuck on is the rectifier having failed in the alternator, basically the battery drains through the igition light leaving you with a flat battery (non start) and a lit dash ignition light......massively annoying but not difficult to fix, just swap the offending rectifier (or indeed whole alternator)
mmmm rusty v8ty goodness
Postby john » 16 Sep 2010 14:01
are you saying the ignition light was on before you inserted the key or turned it to the accessory or when you tried to start the engine
as the ignition light will illuminate and stay on with the key turned
was the ignition light on when the car was running !!!
hymie747
Postby hymie747 » 16 Sep 2010 14:28
Got into car last night and turned ignition key on, then the light came on as engine was turning. Battery seems fine turns over and over and over, but does not start. Thinking maybe lost fire?Was wondering if the light means something is amiss.
Postby jclay (RIP 2018) » 16 Sep 2010 14:46
<font size="1">"Got into car last night and turned ignition key on, then the light came on as engine was turning. "</font id="size1">
This is normal.
<font size="1">"Was wondering if the light means something is amiss."
</font id="size1">
No.
Before trying anything else, hook a jumper wire from the "+" side of the battery to the "+" side of the coil. Try to start the car. If it fires off, then the ballast wire in the wiring harness has perished.
hymie747
Postby hymie747 » 16 Sep 2010 15:47
Thanks I will try tonite at home after work.
hymie747
Postby hymie747 » 17 Sep 2010 01:50
Tried jumping the coil with power from battery, no fire. Checked the sparkplug against the head no fire. The engine turns easily but won't start, no fire to plugs.I will bring some more tools home tomorrow and check for power to coil. Also checked ignition fuses and they were good. Any thing else to look for?
Postby jclay (RIP 2018) » 17 Sep 2010 03:00
I tried to help Zeke get his car started with no spark, didn't work!
I think that I am snake bit when it comes to ignitions. I will let someone else give you advice.
Postby saabfast » 17 Sep 2010 21:45
If jumping a power supply to the coil does not work does that not point to the coil, points, condenser or wiring between? The other possibility which I have encountered many years ago is a problem (crack etc) with the rotor arm. It cannot always be seen. This leaks all the HT power away before it gets to the contacts for the spark leads in the dizzy cap (assuming you have dizzy type ignition).
Saab 9000 2.3 FPT Auto
hymie747
Postby hymie747 » 20 Sep 2010 19:44
OK I checked for power to the plus side of coil and had power but no spark. Then I ran a jumper to plus side of coil and it fired up and ran for about 30 seconds, then quit, no fire again. Pulled capa nd cleaned rotor and cap still no fire. Sounds like something in the electronic ignition. No points or condensers to be seen, so am assuming electronic.Or maybe coil?
hymie747
Postby hymie747 » 23 Sep 2010 18:24
Tried again last night and it fired right up, has a little miss though, maybe a plug wire.Totally lost on this one.
Postby FI Spyder » 24 Sep 2010 16:31
If your HT wires are suspect, change them as a matter of course. I would carefully check the primary wires looking for wire breaks specifically where the connectors clamp onto them which is where they usually break but they could also break in the isulation which is harder to find and usually take some flexing and a hand sweep multi meter as a digital maybe too slow to react to catch the momentary breaks. If nothing shows up it could be electronic parts that could be intermittant.
Users browsing this forum: No registered users and 250 guests
