Dodgy Dipped Beam
Posted: 13 Sep 2010 10:48
I recently changed the sealed units for halogens on my 7. All was working fine when tested.
The next day, I lost dip beam.
Using the console switch, side lights come on fine - but nothing when I put the lights on (pods stay down, lights off).
Using the stalk, 'flashing' the main beam, causes the pods to raise and the high beam flashes, main beam stays off and then the pods lower.
So... the high beam and pods are working and I have changed the dip beam fuses (both). I thought the headlights were wired and worked completely separately (I know that it's the dip beam switching on that raises the pods) so am suprised that they both are failing.
Is there a common relay or fuse in there somewhere???
