Points/Condenser change
The Old One
Postby The Old One » 13 Jun 2010 20:17
I am going to change points and condenser(81 dhc)
Have replaced dizzy cap rotor arm and plugs but
am confused as how to do it as i can not see
how to get near them.Used to working on old
skool fords with nice open bosch dizzys.
Any help and piccies showing how to get in
to do this.
cheers
Postby Beans » 13 Jun 2010 20:40
You'll have to remove the rotor "arm" and retarding weights.
Even than it is still a bit of a squeeze ...
Postby stevie_a » 13 Jun 2010 20:53
<font color="teal"><b>Do what I did
If you are going to do it only do it once
get electronic ignition as it is a B to get into </b> </font id="teal">
[url="http://www.forum.triumphtr7.com/topic.asp?TOPIC_ID=7055&whichpage=3&SearchTerms=ignition"]Image[/url]
Postby saabfast » 13 Jun 2010 21:42
Access is very difficult but I have never removed the weights. Setting the gap is even more of a pain as you need a very short feeler and it is still difficult to see when the points heel is on the cam. They also need checking/adjusting fairly often as they wear and go out of adjustment. As stevie_a, I have just changed to Ignitor electronic ignition (from Retro Rockets) and hope I will not need to look in there again. Certainly, once set up, the timing seems to be more steady and not move about.
Saab 9000 2.3 FPT Auto
Postby Shauniedawn » 13 Jun 2010 22:55
Just take the distributor out. It's much easier to do on the bench.
Shaun
Postby John Clancy » 14 Jun 2010 08:26
Electronic ignition is great but it breaks eventually and then you're stranded. At least with points and condensor you've got a fighting chance of repairing it at the side of the road.
Points gap does increase quickly. Mine has just increased by 4% in 600 miles. However, if you have a dwell angle meter it's a simple process to reset and negates the need for a feeler guage. You may find that's all you need to do right now as when the gap is vastly out the car will run like crap! 39 degrees is the correct setting (+ or - 1 degree) and in percentage terms I believe that is 43.33%.
Postby Beans » 14 Jun 2010 17:07
That's why on longer trips I always carry a spare dizzy with me.
If the electronics decide to go on strike it's only a few minutes work to swap dizzies, and set the timing.
But till date on both cars the electronic ignition has been faultless (by now 17 and 13 years old)
... knock on wood [:D]
Postby FI Spyder » 14 Jun 2010 17:17
I used to spend many a sunday playing with the '71 Javelin playing with points and condenser. I did build an electronic ignition that was triggered by the points (cam follower still wears). (I also made water injection for it.) But the Spider, Tercel and Integra all have electronic ignition and the dwell meter has long been unused in a tool box and I have much more interesting projects to do than play with points. One never gives ignition a thought. If Yellow TCT doesn't have electronic ignition I will convert it over and keep the points and condenser in the trunk pack just in case the after market ignition fails.
Postby John Clancy » 15 Jun 2010 07:52
I'd happily do away with points but having had electronic ignition cause three breakdowns in the past the most viable solution was to revert to the older technology. Almost gave Luminition a try a couple of years ago but since then I seem to have really got on top of keeping the points in tune.
Postby saabfast » 15 Jun 2010 22:02
I was concerned about the reliability of electronic ignition, at least retrofitted to an old car, so left the wiring in place for the points system and drilled a second hole in the base for the electronic unit connections. I carry the points and condenser in the boot so could change back with not much more than the usual hassle of fitting points.
Users browsing this forum: No registered users and 89 guests
