Dash Grille
Dash Grille
Postby Wayne S » 02 Jun 2010 17:18
As anyone successfully managed to fit a 6x9 speaker under the grille on top of the dash? Got any pics? [8D]
Postby busheytrader » 02 Jun 2010 17:31
Have you got room under there? Mine's a mass of loom and connectors.
Postby Beans » 02 Jun 2010 17:43
If you can find another place for the wiring and connectors it should be possible to fit a shallow speaker there [:p]
Bobbieslandy
Postby Bobbieslandy » 02 Jun 2010 17:44
There is another option should the 6 x 9s be too tight, you can buy 6 x 8s, they are an upgrade for ford focus speakers and apart from the obvious, are a little less deep than 6 x 9s. Mine were made by Pioneer but if i remember rightly were only available in pairs. The scrappy should have loads for sale for a couple of quid.
Rob.
Postby stevie_a » 02 Jun 2010 18:12
<font color="teal"><b>Why would you want a 6x9 or any other speaker for that matter fitted there?
you would not get a good sound from it as there is no cabinet for the speaker to base reflex
much better to fit good quality front speakers and sound deadening, with some kind of sub to give some base...Image
this is what I had done recently and it did not cost a lot of money
I have JL audio tr525-cxi coaxials speakers in the front
also a wee bit of dynamat xtreme sound deadening
Alpine SWD-1600 Under Seat Active Subwoofer
A big difference in sound</b></font id="teal">
trv8
Postby trv8 » 02 Jun 2010 18:42
Do they still make them Alpine subs, haven't seen any for sale for a while now [?].
Postby stevie_a » 02 Jun 2010 19:02
<font color="teal"><b>I got mine from e-bay a lot cheaper than this but still for sale on e-bay
[url="http://cgi.ebay.co.uk/Alpine-Powered-Subwoofer-SWD-1600-Car-Subwoofer-B-/120574893750?cmd=ViewItem&pt=UK_Audio_TV_Electronics_In_Car_Entertainment_GPS_Car_Speakers_PP&hash=item1c12d2deb6"]Image[/url]
they are realy good I normally run it at half power as this in well enough </b> </font id="teal">
Postby Workshop Help » 02 Jun 2010 19:43
Again, folks, this bone has been well chewed. The speaker that fits is a 5" by 7" dual cone full range speaker. My spare was bought in 2002 from Radio Shack. This is a company that should remove the 'Radio' from it's name as it no longer sells car speakers.
We added this speaker some 15 to 20 years ago and have replaced it once. Image
Here is the spare speaker.
Due to the limited space in the dash speaker compartment, use a speaker with a smaller magnet on the back as a large magnet will not fit.
What is nice is standard size speakers in the door panels combine with the dash speaker to flood the cabin with just the right amount of sound without it being overwhelming. I like it this way.
Postby PeterTR7V8 » 02 Jun 2010 19:54
You can buy flat panel speakers for computers. They will need to be aadapted & I suspect they are not high powered but with a sub the should be OK. Just search google for flat panel speakers.
Postby Wayne S » 02 Jun 2010 21:10
Hi Mildred, that was exactly what I was curious about.
As you say Stevie, no point putting a bass end speaker there as it will just rattle the dash with no benefit but a full range one like Mildred has would reflect sound from the windscreen to give you a face up direction. If you combined that with your behind seat sub then I reckon that would have great effect.
Loving the sound deadening too [:D]
Presumably the factory did consider this as otherwise why put the hole there with the correct shape etc? And a grille over it too....
trv8
Postby trv8 » 02 Jun 2010 21:28
Wayne, Dynamat is expensive [:0]. I used the sticky backed roof flashing from any builders supliers.
Comes in all differet sizes and does the same job but much cheaper [:D].
Postby gaz » 02 Jun 2010 21:35
what the hell do you want more speakers for wayne youv'e got a V8 soundtrack.................
Postby Odd » 03 Jun 2010 14:34
<blockquote id="quote"><font size="1" face="Century Gothic, Verdana, Arial, Helvetica" id="quote">quote:<hr height="1" noshade id="quote"> ... would reflect sound from the windscreen to give you a face up direction ... <hr height="1" noshade id="quote"></font id="quote"></blockquote id="quote"> I fitted a pair of tiny piezo tweeter balls in the outer corners of the windscreen
- to get just that effect. No holes since the wires goes down through the
already-there gaps in the screen plastic. Works a treat...
<blockquote id="quote"><font size="1" face="Century Gothic, Verdana, Arial, Helvetica" id="quote">quote:<hr height="1" noshade id="quote"> Presumably the factory did consider this as otherwise why put the hole there with the correct shape etc? And a grille over it too... <hr height="1" noshade id="quote"></font id="quote"></blockquote id="quote"> Yes - in 1974-75 or so. The 'grille' was even perforated at that time,
but they quickly left the idea since all the harnesses needed that space
- and speekers (plural) were better placed in the doors...
Craig C
Postby Craig C » 04 Jun 2010 00:28
Sorry to slightly hijack the thread, but it is reasonably close...
Has anyone made a replacement for the grille-y thing that covers this hole that doesnt warp in the sun? Okay, I live in Alice Springs so probably have more sun/heat than most, but I would be pretty sure most cars would have experienced a hot enough day that this plastic panel is now warped beyond use.
I was thinking of making a panel that would incorporate either guages or satnav and am wondering if anyone else has gone down this line?
Craig
Tr7V8
Postby jclay (RIP 2018) » 04 Jun 2010 01:05
Yes, there was a guy about three years ago that built a matching cover that was wedge shaped that had three gauges installed. Couldn't find the photos.
Users browsing this forum: No registered users and 108 guests
