Tail Lights
Posted: 29 May 2010 01:33
Over the holiday weekend I plan to debug the tail/signal/running lights on the '80 DHC.
Currently only the brake lights work and they are dim; on the brink of being dangerously dim. Hey, we don't have MOT's here we just get fast driving awards.[:0]
After studying the wiring diagram I feel the problem is within the hazard switch, but that's not my question, I can fix the wiring/switch/contact/flasher problem.(they were working intermittently a while ago)
The problem is the brightness of the tail lights in general. They don't look that dirty and I have not looked at the reflectors yet. I will measure the voltage at the bulb sockets when I get power to them, that might be the problem. If not, if the sockets are getting the required voltage, has anyone succeeded in finding bulbs that are brighter than normal?
I know that within the last 2 years some LED's have came out that will just about blind you and I have a few thousand at work but if there is an off the shelf replacement that would work I would try that first. The problem with the ones I have at work is they generate a huge amount of heat and require a heat sink also like most LED's they project light predominantly in only one direction and not omnidirectional like filament bulbs. I don't want to build an array of LED's on a PWB the same shape of the tail light sections...Hummm, wonder if that would sell....( I got dibs on the idea ! you heard it here first It's published now !!!)[8D]
Anybody tackled this issue? Suggestions? Or am I asking too much of a 30 year old classic?
