tr7 conversion
pintos21
tr7 conversion
Postby pintos21 » 27 May 2010 15:23
I am working on a 1977 tr7 that has been sitting since 1984 and cannot get it started.So I,m thinking about another motor,Land Rover or Buick. My question is the years to look for.J R
Jerry Rees
Postby FI Spyder » 27 May 2010 16:27
If the engine turns it should start. You can do a search to find other posts about starting an engine that has been sittting. This includes new wires, sparkplugs, cap, points, fresh gas direct to full pump, cleaned carbs (possibley new diaphrams in overhaul kit). The problem is time may have deteriorated rubber parts and the gas will have turned to varnish. These steps are true of any engine that has set for a years. Stacey David devoted a whole episode to this on his TV show Gearz. If you are going to drop in a V-8 anyways don't bother going through these steps. If it's a four speed you will need a 5 speed tranny and rear end to handle the power. You other options is a Buick V-6 and you can get a kit from John's Cars (see other forum section dedicated to this.) A very viable option as it moves the weight distribution to the rear for better handling.
The Buick V-8 was available 1961 to 1963. Olds used a high performance version with a slightly different head and 10 to 1 pistons. It was used by Rover up until the 2004 Land Rover Discovery.
Jolyon39
Postby Jolyon39 » 27 May 2010 20:33
Welcome to the forum Jerry
The TR8 had the Rover V8 which was found in the SD1 Rover.This has the correct sump and front cover for fitting the engine into the TR7.
If I were in the US though I would go the Johns Cars direction as that 6 cyliner version of the Buik V8 is about 220 horse in standard fomat versus the Rover V8 at only 155 Horse.
Jolyon
Postby PeterTR7V8 » 27 May 2010 21:40
Also, the Land Rover 3.5 V8s were lower compression so unless it is a 3.9 version it will not be up to TR8 spec.
What have you done to get the motor started? Got a spark? Is fuel flowing?
pintos21
Postby pintos21 » 29 May 2010 11:04
Jerry Rees
pintos21
Postby pintos21 » 29 May 2010 11:58
<blockquote id="quote"><font size="1" face="Century Gothic, Verdana, Arial, Helvetica" id="quote">quote:<hr height="1" noshade id="quote"><i>Originally posted by pintos21</i>
Jerry Rees
<hr height="1" noshade id="quote"></font id="quote"></blockquote id="quote"> Thanks for the help. I've done all the standard stuff to get it running.Spark,fuel,compression.Compression in cylinders 1 and 2 in the 90s 3 and 4 in the mid 80s.Set timing. I,m not sure where to go from here will have to look at some other options J.R.
Jerry Rees
Postby FI Spyder » 29 May 2010 18:24
ge<blockquote id="quote"><font size="1" face="Century Gothic, Verdana, Arial, Helvetica" id="quote">quote:<hr height="1" noshade id="quote"><i>Originally posted by pintos21</i>
It seems to me the compression should be in the 150 range, I've just checked my book were I have my Spitfire compression readings stored. Sounds like the valve timimg is out. Tensioner may have allowed the timing chain to have slipped a tooth or two. I would take the timing chain cover and valve cover off and check things out. You can download the OEM service manual in pdf from jclay's website. Unless you still want an engine change anyways then it's just academic.
Squirt some oil in the spark plug holes and see if it goes up. Maybe stuck piston rings? What do you guys think?
Users browsing this forum: No registered users and 98 guests
