took the car out the garage
Postby john 215 » 12 May 2011 22:52
Hi stevie,
found the connector under the speaker grille, if i disconnect this loose all N/S indicators, apart from the insrument cluster repeat lamp this stays on pernamently.
Postby stevie_a » 12 May 2011 23:01
<font color="teal"><b>thanks john</b></font id="teal">
Postby stevie_a » 14 May 2011 20:52
<font color="teal"><b>OK I am at it again ...[:(]
Update:
after getting another flasher unit ...[:(]
I ran another wire from the back indicator to the wire that is supplied from the left indicator switch
so not to blow another flasher unit i bridged the two wires that go on to the unit with solder wire
so if it started to burn it would just snap the solder
now to my big surprise I had left and right indicators ....[:)]
obviously not flashing as no flasher unit in system
so I connected the flasher unit
right hand indicators working fine
nothing at left hand side...[:o)]
took flasher unit back out and put fuse wire back in, got left and right none flashing as you would expect
what the he** is going on
Any help</b></font id="teal">
Users browsing this forum: No registered users and 286 guests
