RetroSound Radio
RJS
Postby RJS » 22 Jun 2012 18:39
Take a look at the links. I ordered the digital one, but they sent the analog one. I think I still want the digital, but I am thinking the analog is more retro and might look more appropriate.
Opinions?
http://www.pyleaudio.com/sku/PLR14MUA/In-Dash-AMFM-MPX-MP3-Dual-Knob-Radio-wUSBSD-Card
http://www.pyleaudio.com/sku/PLR14MPF/In-Dash-AMFM-MPX-MP3-Shaft-Style-Dual-Knob-Radio-wUSBSD-Card
sydney.wedgehead
Postby sydney.wedgehead » 22 Jun 2012 18:59
IMHO, the digital looks better, and would be more useful to me as it has an AUX input.
But, the LCD display will probably be harder to read than the other unit during the daytime due to std installation angle, so if you change your radio station much the analog could be the way to go.
Postby FI Spyder » 23 Jun 2012 14:22
I like the analog, it looks very period. Might even fool the Collector Plate guys that require a period radio although that slot and rectangle hole thingy might not get by.[:p]
rgsSpider
Postby rgsSpider » 23 Jun 2012 16:27
So any clues on that wiring diagram?
Randy
sydney.wedgehead
Postby sydney.wedgehead » 23 Jun 2012 17:10
What you described seems correct.
The only thing to check is that the feed is live with the ignition key in the "accessory" position rather than in "on" position.
DutchTriumph
Postby DutchTriumph » 23 Jun 2012 17:22
Numbers 1-8 are for the speakers
Ground (neg), Black:....0V for the radio
12V, Yellow:..................Power supply for the radio, switched with the ign. key
Dial lamp, Blue:............Light behind the dial and buttons, connect to dash light
Power antenna, White:.To raise an (optional) antenna with motor, when the radio is switched on.
These old fashioned radio's have a mechanical selection for the radio station, so there'e no constant 12V for a memory needed.
Peter
rgsSpider
Postby rgsSpider » 23 Jun 2012 18:48
Thanks, but I'm wondering about the speaker wires. These days you have two wires going to each speaker. This setup indicates one wire to each speaker and the other wires go to ground. You can't wire modern speakers in this way can you? I was thinking I could take one black (ground) wire to each speaker which would give me two wires to each speaker. The problem is, I don't know which black goes to which color.
Also, thanks for clarifying the 12V wire, I hadn't thought about that but it makes sense.
<blockquote id="quote"><font size="1" face="Century Gothic, Verdana, Arial, Helvetica" id="quote">quote:<hr height="1" noshade id="quote"><i>Originally posted by DutchTriumph</i>
Peter
Randy
DutchTriumph
Postby DutchTriumph » 24 Jun 2012 08:54
The difference is in the modern (high power) amplifiers. Each speaker has its own "ground", and are not connected to the ground (0V) of the radio.
On old fashioned radios, the speakers and the radio all use the same ground.
Peter
rgsSpider
Postby rgsSpider » 24 Jun 2012 13:20
So it doesn't matter which ground wire goes to which speaker, as long as each speaker receives a ground wire?
Randy
DutchTriumph
Postby DutchTriumph » 24 Jun 2012 18:22
<blockquote id="quote"><font size="1" face="Century Gothic, Verdana, Arial, Helvetica" id="quote">quote:<hr height="1" noshade id="quote"><i>Originally posted by rgsSpider</i>
That's right! On modern radio's the ground for the speakers have different colors. On this one they are all black. It doesn't matter witch one you use. If you measure them with an Ohm-meter, you'll see all the black ones are connected to each other.
Peter
rgsSpider
Postby rgsSpider » 24 Jun 2012 20:15
Awesome! Thank you! Now I've got to get the cassette player working. I sure would love to be able to get this thing working and installed! I've sent out some messages to repair places but so far it sounds like most people just want to work on newer ones.
Randy
rgsSpider
Postby rgsSpider » 26 Jun 2012 20:25
I took the radio to a repair shop today, hopefully they'll get it running good as new.
I received two C shaped brackets with the radio and can't figure out how they are used to install. They obviously go over the control shafts, but in which direction and what do they attach to? I've got a spare console that I tried to fit it too but didn't have much luck.
Randy
darrellw
Postby darrellw » 26 Jun 2012 20:28
I believe they go over the shafts, then you sandwich the console between them and the face plate. Hopefully that makes sense!
Darrell Walker
66 TR4A IRS-SC CTC67956L
81 TR8 SATPZ458XBA406206
Vancouver, WA, USA
Postby FI Spyder » 26 Jun 2012 23:21
Pictures taken as I was removing dash to refoam heater. I have since removed the purple spacers and used washers to more precisely control the position of the brackets.
rgsSpider
Postby rgsSpider » 27 Jun 2012 00:24
Great pics, thanks for those! I was wondering what the single spacer was for too. Sounds like I'll be getting some washers too.
Randy
Users browsing this forum: No registered users and 193 guests
