took the car out the garage
Postby stevie_a » 08 May 2011 18:18
<font color="teal"><b>Just when I thought I had cracked it with the electrics
the Bl**dy left hand indicators yet again start frying the flasher unit again
ah well another dash strip down, it is maddening because it is intermittent,
will start working fine for a week or so and all of a sudden the fault returns ,
today i was driving for 45 minutes then on one left turn no indicators,</b></font id="teal">
Postby stevie_a » 11 May 2011 20:48
<font color="teal"><b>Ok help please
This photo shows a connector under the speaker grill
I know the wires are for the left hand indicators
as you can see the connector is heat burnt
where do these wires come from a go ?
one I think comes from the hazard switch a green and red
I think the green only would go down to the front bulb
and the other goes to the rear bulb
but I cant see because it all goes into the loom
all help appreciated</b></font id="teal">
Henk
Postby Henk » 11 May 2011 21:31
What is that blackbox under the connector on the shelf?
Henk
1980 TR7 US Convertible
1978 Mini Clubman Estate
Postby stevie_a » 11 May 2011 21:33
<font color="teal"><b>It is the vibration box for the alarm.</b></font id="teal">
Postby stevie_a » 12 May 2011 21:45
<font color="teal"><b>Update:
I now have hazards, I had to disconnect these wires which were connected
Should they be connected ?
They are located at the end of the cable coming from the front left indicator</b></font id="teal">
Steve @ SandS
Postby Steve @ SandS » 12 May 2011 21:49
No, whatever you do don't connect them.they are the connections for the marker lights, the green being the feed from the indicator and the black is an earth.
Steve @ S&S Preparations
Postby john 215 » 12 May 2011 21:53
Hi Stevie,
Looking at those wires, you have a green and another colour, the other wire is black [?] [?], IF this is the case i would say no, black on BL cars is always an earth,so if green colour is live at somepoint then never a good connection to make [xx(]
Will have a look under my speaker cover see what i can see tomorrow.
Postby stevie_a » 12 May 2011 21:55
<font color="teal"><b>This is what I found out when testing
But the thing is they were connected [:0]
and always have been[:I]
I disconnected then I had my hazards back
still no indicators yet..[:(]</b></font id="teal">
Steve @ SandS
Postby Steve @ SandS » 12 May 2011 21:57
The same wires are on the RH side as well, make sure they aren't connected.If these wires are you will blow the indicator fuse.
Postby stevie_a » 12 May 2011 22:03
<font color="teal"><b>Steve I am not blowing any fuses Just flasher units..[:(]
On Sunday I was driving, everything was fine
then all of a sudden on one left turn, nothing </b></font id="teal">
Steve @ SandS
Postby Steve @ SandS » 12 May 2011 22:08
Hmmm, seems odd that they were connected.Any idea how long they have been like that ?? There's a red/yellow wire down there as well which is for thew front fogs.That's not connected to anything it shouldn't be is it ??
Postby stevie_a » 12 May 2011 22:13
<font color="teal"><b>I seen that one, It is not connected to anything</b></font id="teal">
Postby john 215 » 12 May 2011 22:21
Hi Stevie,
What fuse do you have in the hazard circuit as that should blow before the unit, cheaper too
Is there a second colour on that green wire at a guess red [?]
Postby stevie_a » 12 May 2011 22:27
<font color="teal"><b>Fuse ratings are all OK, I have checked them John
the wires under the grill are one single green and on the other side of the connector
has two wires both red and green</b></font id="teal">
Postby john 215 » 12 May 2011 22:31
Hi Stivie,
Green Red is for N/S indicator ( green white is O/S )
Will go and lift the top off mine now and have a look, wont get to sleep if i dont !!!! sad i know [:I]
Users browsing this forum: No registered users and 216 guests
