Well I'm in the process of putting in my new radio. Yay me! I'm not going to tell what it is yet, but it's am/fm/USB/SD/audio port. I did a test fit today and as far as I can tell its a perfect fit...with no parts sticking out or anything.
This has also given me an opportunity to fix a few things. Cigarette lighter wasn't working. Took it apart, cleaned it out good, put it back together, works fine. (just like the fix for the light switches, etc. we need to come up with a fancy, complicated sounding name for this fix) The rheostat was working, but there was a rather large white wire hooked up to. The original wire was taped up and not being used. I swapped them out and it still works! Perhaps that was one of the rat-chewed wires I fixed when I got the car. A/C switch worked fine. Thanks to the forums I was able to get the knobs removed and got the switches out of the old console. There was a mess of wires down there. I traced them one by one. Turns out the radio that was in there before the current one (not the new one) was removed by just cutting the wires and leaving them all in there. What a nightmare! Then I found piggybacked wires that went to nowhere. So I got everything cleaned out, straightened up, and ready to go. I bought a set of rear speakers on eBay from Woody's. For now I've got the speaker wire quick-disconnect ready to go. Tomorrow I start off with the power quick-disconnect. I found a wire that's part of the front speaker harness that hot when the key is on, and another which I'm guessing is a ground. Does anyone have a suggestion as to an easy-to-get-to always hot wire that I could piggyback onto? I don't like running wires into the fuse box.
So I'm excited, tomorrow should be the day I do a test hook-up before I start buttoning everything up. This isn't an expensive system, but I'm hoping with that and four speakers I'll get some decent sound.
And yes I'll have pics of the completed project!
Randy
http://web.me.com/rg_spb/TR7_Spider/Home.html
