New Wheels!
Postby Beans » 20 Jun 2013 18:12
<blockquote id="quote"><font size="1" face="Century Gothic, Verdana, Arial, Helvetica" id="quote">quote:<hr height="1" noshade id="quote"><i>Originally posted by trekcarbonboy</i>
... the rear axle sticks out the right side 3/4 of an inch further than the left ... <hr height="1" noshade id="quote"></font id="quote"></blockquote id="quote">
Checked the difference on my DHC because on that car I checked the dimensions of the mounting points in relation to each other.
Mounting points are well within the factory specs (so less than 1 mm difference), so a very straight car.
But the clearance between rim and rear arch is 15 mm less on the RH side compared with the LH side.
trekcarbonboy
Postby trekcarbonboy » 20 Jul 2013 13:07
Only about 300 miles on my new tires and I already have an irreparable screw in the tire! [:(!]
Craig '75 2.0 FHC
Postby Cobber » 20 Jul 2013 13:26
<font size="2"><font face="Comic Sans MS">The problem of rear axle offset is an inherent result of Triumph's decision to use a Panhard Rod instead of a Watt's Linkage to laterally locate the rear axle.
The more the car is lowered to more pronounced it will be.
</font id="Comic Sans MS"></font id="size2">
'98 MG-F, 69'Ford F250.
trekcarbonboy
Postby trekcarbonboy » 20 Jul 2013 14:10
[quote]<i>Originally posted by Cobber</i>
[?][?][?] Huh? There's no panhard rod on my car. Or is there?
Craig '75 2.0 FHC
Postby Beans » 20 Jul 2013 15:54
<blockquote id="quote"><font size="1" face="Century Gothic, Verdana, Arial, Helvetica" id="quote">quote:<hr height="1" noshade id="quote"><i>Originally posted by Cobber</i>
... The problem of rear axle offset is an inherent result of Triumph's decision to use a Panhard Rod instead of a Watt's Linkage to laterally locate the rear axle ... <hr height="1" noshade id="quote"></font id="quote"></blockquote id="quote">
Euhh ... je ne comprends pas aussi [8)]
BL only used the 5-link Panhard rod set up for their competition cars.
Normal Tr7's have a symmetrical 4-link set up, with parallel lower links and angled upper links.
supercass
Postby supercass » 20 Jul 2013 16:41
<blockquote id="quote"><font size="1" face="Century Gothic, Verdana, Arial, Helvetica" id="quote">quote:<hr height="1" noshade id="quote"><i>Originally posted by nick</i>
With such a large contact patch how much force is it taking to move the steering wheel when the car is stopped?
I had it drilled into me by my driving instructor that you should never move the steering wheel unless the car is in motion, i.e. at least creeping forward. supercass
Postby Beans » 20 Jul 2013 17:26
<blockquote id="quote"><font size="1" face="Century Gothic, Verdana, Arial, Helvetica" id="quote">quote:<hr height="1" noshade id="quote"><i>Originally posted by supercass</i>
... I had it drilled into me by my driving instructor that you should never move the steering wheel unless the car is in motion ... <hr height="1" noshade id="quote"></font id="quote"></blockquote id="quote">
That's showing your age, but at least in the old days driving instructors knew what they were talking about [:D]
jrich4411
Postby jrich4411 » 21 Jul 2013 14:05
Trek - where did you pick up these wheels?
'80 DHC
Chevy V8 up front
Ford rear end down back
Lucas wiring all over
trekcarbonboy
Postby trekcarbonboy » 21 Jul 2013 22:11
18racing.com
style: RB Classic, 15x7
Craig '75 2.0 FHC
Postby Beans » 22 Jul 2013 07:18
Only about 300 miles on my new tires and I already have an irreparable screw in the tire! [:(!] <hr height="1" noshade id="quote"></font id="quote"></blockquote id="quote">
Unless it's in the side wall a good tyre shop should be able to plug such a hole ...
trekcarbonboy
Postby trekcarbonboy » 22 Jul 2013 10:11
It was right in the corner bend of the sidewall. I thought it looked repairable but 2 different tire shops said no. [:(]
Craig '75 2.0 FHC
jrich4411
Postby jrich4411 » 22 Jul 2013 20:19
18racing.com
Craig '75 2.0 FHC
Very nice find - and surprisingly affordable!
'80 DHC
Chevy V8 up front
Postby Beans » 23 Jul 2013 04:35
It was right in the corner bend of the sidewall ... <hr height="1" noshade id="quote"></font id="quote"></blockquote id="quote">
That indeed will write off a tyre [B)]
Postby Cobber » 23 Jul 2013 05:01
Hmmmmmm! my car has a Panhard rod, must've been fitted by a previous owner then. I thought it was original, must have a proper look when next I get under it</font id="Comic Sans MS"></font id="size2">
Postby Beans » 23 Jul 2013 11:37
Sounds interesting so please don't forget to take some pictures [:)]
Users browsing this forum: No registered users and 347 guests
