Possible steering prob bcse: Inner ball joint was loose, but looking in I discovered a hose clamp!! over the adjusting (?) nut... presumably keep it in place (?) The mechanic I'm working with said he could drill and tap the nut and use a set screw to keep nut from loosening again...
Has anyone had experience adjusting/greasing those inner ball joints? Many thanks
Tom
'76 FHC, V6, under construction
