<font size="2"><font face="Comic Sans MS">I recently fitted a water level sensor kit to my MGF from Brown and Gammons: http://www.ukmgparts.com/product.aspx?CID=a6438a2a-06ce-45d6-a18f-943e9e1c4240&SID=ebec95df-7260-440a-8983-8643a1d15510&PID=91827d9b-18de-491e-b074-a1f29941307a also available from Rimmers: http://www.rimmerbros.co.uk/Item--i-RP1477
This is a bloody good bit of kit, as it gives you peace of mind in being able to shut down the engine if a sudden loss of coolant were to occur due to say a ruptured radiator hose etc. and it occurs to me that it should be easy to adapt to our Triumphs.
It features both a warning light and audible signal, it also has a test function every time you start the car and a delay to prevent false signals from the float bouncing about. It's basically plug and play, in the MGF it just connects it to the reversing light wiring, so you could probably do the same with a TR-7/8.
I'm seriously thinking of ordering another for this very purpose, I have the old expansion tank from the MGF to use as a mock up for making the mount and adapting it, as easy as crapping in bed and kickin'it out with your feet. (a bloody lovely Aussie turn of phrase that!)[:D]</font id="Comic Sans MS"></font id="size2">
'98 MG-F, 69'Ford F250.
