Subframe to body polybushes too small?!?!
Bobbieslandy
Postby Bobbieslandy » 31 May 2010 00:43
Hi all,
I started to fit the polybushes to my subframe and noticed the ones which fit between the top of the subframe and bottom of the body, or in my case, top of the subframe and bottom of the aluminium subframe spacers appear too small. i was expecting them to be half the thickness and twice the diameter, or the same size as the old ones i just took out! do these sound like the right ones?
Thanks,
Rob.
Postby PeterTR7V8 » 31 May 2010 01:13
They will look like this. The yellow ones are the rear bushes & the smaller bushes go between the chassis & the subframe..
Bobbieslandy
Postby Bobbieslandy » 31 May 2010 20:22
Thanks Peter,
I was wondering if i had the right ones. Once the subframe bolts had been tightened they did compress quite a bit and ended up looking like the originals!
Rob.
Postby Beans » 31 May 2010 21:06
They shouldn't compress that much.
Make sure the steel inserts are in good condition.
Postby Hasbeen » 31 May 2010 22:55
Rob, as Beans says, with the steel spacers in good condition, there
should be very little compression. Not enough for you to see a
change of shape as you tighten them.
Have another look at them.
Postby Beans » 01 Jun 2010 10:10
... they did compress quite a bit and ended up looking like the originals! ... <hr height="1" noshade id="quote"></font id="quote"></blockquote id="quote">
This is how they should look with the sub frame bolts tightened up ...
Bobbieslandy
Postby Bobbieslandy » 01 Jun 2010 19:17
Ah, mine look a bit squashed!
I believe i'm missing the 4 steel inserts which sit in the lower bushes, hence the old bushes being crushed. I think longer bolts are in order too!
Thanks Guys.
Rob.
Postby REPLIC8 » 01 Jun 2010 21:09
Rob, if you're not running a V8 why are there spacers between the chassis & the subframe? There shouldn't be any clearance problems with a 2 litre engine.
Postby Beans » 01 Jun 2010 21:10
What did you place between the polybush and the chassis leg ?
Bobbieslandy
Postby Bobbieslandy » 02 Jun 2010 05:40
The Spacers came with the car, something to do with lowering the roll center and giving slightly more negative camber. As they came with the car i thought i'd leave them there but with hind sight i might remove the subframe to body bushes and fit thin rubber between the aluminium spacers as protection. It's either that or fit the inserts which i'll have to do anyway and get hold of some longer bolts. The trouble started when i noticed the original bushes (subframe to chassis) were twice the diameter and half the thickness. I now know that's because they'd been crushed! in order, from the chassis leg down i've got...
Subframe spacer, bush with insert which is being forced down into the bush below, subframe, subframe bush (no insert) and a shaped, thick washer on the rear and normal large washer on the front.
You say there's no clearance problems, even with the spacers the bonnet is very close to the oil filler cap. With the bonnet off you can see the filler cap is actually higher than the wings. At one point i didn't think it was going to fit. Maybe it would fit, i'm not 100% sure but i wouldn't fancy shutting the bonnet without those spacers fitted!
Rob.
Postby PeterTR7V8 » 02 Jun 2010 06:09
I hate it when you get called on something on your car that's out of place when a PO put it there & you don't know it isn't meant to be, [xx(]
Did the old bushes not have the steel tube inserts? My poly bushes are squished a bit but not nearly as bad as yours Rob.
Postby REPLIC8 » 02 Jun 2010 06:54
If you're eyeing through from wingtop to wingtop parts of the engine will protrude above. My carbs are about 2" above this line. There is quite a curve to the bonnet plus the bulges to accomodate this. Looking at the photos, if you remove the spacers & use the proper steel inserts for your polybushes so they don't compress it will only raise the subframe about 5mm. If it's all standard things should fit just fine. [:)]
Bobbieslandy
Postby Bobbieslandy » 02 Jun 2010 09:45
That's totally cool Peter, it's to be expected on a 32 year old car i guess. I must admit that this is the first "old" car i've bought where the wiring has not been butchered by a p/o though so that's some consolation! I'll make some inserts up, remove the spacers and take it from there, 5mm can't make that much difference surely? ( i feel i may be quoted on this!). this is what keeps things interesting [:)]
Rob.
Postby Beans » 02 Jun 2010 17:55
Unless you fit Webers with a certain throttle linkage on top you shouldn't have any clearance problems with the Sprint engine.
If in doubt don't slam the bonnet shut but lower it gently [:p]
Users browsing this forum: No registered users and 138 guests
