<blockquote id="quote"><font size="1" face="Century Gothic, Verdana, Arial, Helvetica" id="quote">quote:<hr height="1" noshade id="quote"><i>Originally posted by Launie</i>
Spyder, I have a carport "tent" like that too. It's full of junk, including spare TR7 parts.
With the wet snow the roof sags pretty bad and I keep scraping it off to keep it from collapsing. Annoying. Don't you find that problem?
So what's the solution? By the time I finish bracing the whole thing, I'll have built a garage inside the tent!
Launie
I thought I could build my own cheaper than but one (didn't quite turn out that way.) I used plumbing pipe for the frame and made the cross pieces out of different sized pipe so they would slide in each other so the wideth would be adjustable. It is reinforced by 1x3 treated lumber diagonally attached with chain link fencing attaching hardware. I had made a roof out of ABS pipe that I bowed and attached with large ties but in it's first winter two years ago it broke under the weight of the second day of snow. (the snow here is very wet and heavy). I had forgotten to shake off the first day's snow. So in the summer I made an A frame of 2x2 (in two halves for easy installation) and attached runners of strips of plywood (light weight) to support the tarp. The roof is all screwed and supports are all bolted so theoretically I could dismantle it and reassemble it if I needed. It lasted through our three winter storms (the fourth missed us) last year despite the fact on of our trees didn't as one up rooted and fell on our neigbours house cracking his roof ridge and knocking out the power for three days. (It had snowed (wet), frozen, then high winds came up causing many millions of dollars of damage and hundreds of power outages across the province.) If it can go through that I'm pretty confident it will stand up to whatever we get.
If you want I can email some pics of the attaching details.
