TR7 Clutch Issue
tzorzo
TR7 Clutch Issue
Postby tzorzo » 09 Jan 2019 06:45
HELP.
I have an issue with my clutch.
Installed motor and gearbox into my car.
had an issue with the clutch engaging removed the slave cylinder and pulled the rod attached to the clutch fork too far forward now it won't go back.
Any ideas on a fix without removing the gearbox?
Regards
Tony Zorzo
Re: TR7 Clutch Issue
Postby saabfast » 09 Jan 2019 12:42
Ouch, not good!
From memory the end of the rod fits into plastic clip on the fork. There were a few threads (on the old forum I think) where people with this problem had managed to get it reattached by using loops of string to pull the fork IIRC. If the plastic clip (which can be brittle) has broken it will be a bit of a challenge.
EDIT Found this old thread with a search which shows one way to overcome the problem:
viewtopic.php?f=3&t=13776&p=103649&hilit=slave+rod#p103649
also, but not too descriptive:
viewtopic.php?f=3&t=11546&p=83197&hilit=slave+rod#p83197
tzorzo
Postby tzorzo » 09 Jan 2019 19:14
Allan, thanks for reply but my is is that the for has come all the way forward in the bell housing and now wont go back to correct position.
I am assuming that the bearing has come out of the 2 lugs on the fork.
Regards
Tony Zorzo
Postby saabfast » 09 Jan 2019 21:53
That's worse! :cry: Sorry, I do not know of any way to get the release bearing back onto the slipper blocks without dropping the 'box. Good luck.
Postby busheytrader » 10 Jan 2019 03:00
Your initial problem with the clutch.........
Did the pedal go down to the floor with little resistance, then come back up and stay stuck solid? That's what happened to mine when the fulcrum pin finally wore a hole through the clutch fork. IIRC, the engine and gearbox have to be separated to replace these.
The latest replacements have a strap welded behind the vulnerable pin recess. https://rimmerbros.com/Item--i-LBU1234
Postby FI Spyder » 10 Jan 2019 15:39
If you never had the trans off before and have to pull it now would be a good time to chck for clutch wear, flywheel marks, sheen (radially clean any rust off with emery cloth), rear engine seal for leaks (replace with new). I pulled the box out the bottom as I figured it was easier than pulling engine out the top but your situation may vary. I hate doing it as it's a lot of work (if you don't have to do anything else like general clean up.
Postby saabfast » 10 Jan 2019 20:56
When my clutch jammed it was one of the torque springs in the friction plate had broken and jammed between the pressure plate and friction plate. Luckily is was close to home so managed to get back in the gear it was stuck in.
Assuming yours is a 5 speed car you will need to get the pretty high to get the box out from underneath (as I did too) as the bellhousing is pretty big and the box is VERY heavy. (Assume the 4 speed has a similar size bellhousing but its a lightweight). I used two trolley jacks and made up a timber 'tray' to fit the bottom which a jack went under.
While it is out also check the shift extension bushes, shift rod oil seal, rear oil seal and maybe the pump, and check the crossmember mount has not turned to jelly.
Postby Beans » 11 Jan 2019 11:14
tzorzo wrote:Allan, thanks for reply but my is is that the for has come all the way forward in the bell housing and now wont go back to correct position.
That sounds like a gearbox out job to me if the fork doesn't go back in its position :shock:
Postby dursleyman » 11 Jan 2019 17:17
If its just the rod come out of its clip on the fork there is a way I have seen to put it back with having to remove the grearbox. Pretty sure it was on here but I saved a copy just in case so this might be worth a try?
https://drive.google.com/open?id=0Bz1MK ... HFtZjVzZjg
1981 TR7 Sprint DHC
Users browsing this forum: No registered users and 27 guests
