It lives! Sort of.
johnnyj
It lives! Sort of.
Postby johnnyj » 13 Jan 2019 19:40
Hi folks
Over the last few weekends I have been re-installing the wiring loom and connecting everything up. That I didn't label anything when I took the loom out over 20 years ago hasn't helped, but I believe I have done a good job getting everything back in and retro-labelling using the circuit diagram and a spare loom. I'm not rushing this job, as I want all the electrics to work before refitting the dash etc.
So, after much repairing of the loom I applied some 12v power from a battery today (the engine isn't in, so all engine wires etc were insulated with tape to stop any shorting). My view was that any number of things would happen, namely (a) nothing would work (b) it would blow all the fuses, catch fire and burn my garage down :roll: (c) some things would work and (d) it would all work perfectly. Clearly (d) wasn't really going to happen, but here's what did:
Working: Rear side lights, rear stop lamps, reverse lamps, boot lamp, indicators, horn, centre console green lamps, cigar lighter lamp, instrument back lighting, instrument turn lamps, clock, front side lights, front indicators.
Working but weirdly: Numberplate/licence plate lamps in the boot/trunk lid (dim), hazard lights (they did work for a while but now don't), headlamp lift motors. One is always up and doesn't move, the other goes up when it should be down and vice versa
Not working at all: interior light, instrument cluster vertical centre warning erm things (choke-on lamp, ign, oil brake, coolant etc), washer pump, wiper motor (which is getting very hot. I did say it might burst into flames... :shock: )
I have listed these just in case someone with better knowledge than me may say "aha, some of those things share an earth or +VE feed in common".
One other thing, I have a mystery around the low fuel delay unit but I may be confusing it with something else. I have four wires, the colours of which according to the book correlate exactly with this part. However they are after the grommet on the loom which exits I think in the same hole used by the wires which feed the low brake pressure switch which screws into the bottom of the brake master cylinder. That would position the low fuel delay unit somewhere in the engine bay, right in the corner of the front bulkhead/RH inner wing on this RHD car, roughly opposite where the washer pump goes on the other side of the car. I almost remember some rusty thing being there when I took the car apart. There are correlating holes there for it, or something similar.
However, everything I read says the low fuel delay unit is fitted somewhere inside the car, perhaps underneath the instrument cluster.
So, am I confusing two parts?
Thanks all
Triumph TR7 FHC, 1977
http://t-r-7.blogspot.co.uk
HDRider
Re: It lives! Sort of.
Postby HDRider » 13 Jan 2019 20:26
Later cars have the delay unit mounted on the back of the instrument pod. I believe that you are correct about your car's being mounted on the bulkhead.
Edward Hamer
Petaluma CA
johnnyj
Postby johnnyj » 13 Jan 2019 20:32
Man, you may have saved my sanity there! Many thanks.
johnnyj
Postby johnnyj » 14 Jan 2019 18:57
I am a bit confused again. Easily done with me!
Lots of threads talk about a voltage stabiliser which smooths out the spikes in the 12v supply to the dash, and supplies 10v. It looks exactly like the fuel low delay unit, UKC7096, according to the photos. However it strikes me that both would appear to do the same thing. Are they the same thing on my car?
Does my car need both, in which case does anyone know the p/n for the stabiliser? Or does UKC7096 serve both purposes?
Thanks everyone
Postby Beans » 14 Jan 2019 19:50
Can't help you at the moment as my computer crashed last week. So can't check my pictures. Hopefully it'll be back and running soon.
johnnyj
Postby johnnyj » 14 Jan 2019 19:53
Beans wrote:Can't help you at the moment as my computer crashed last week. So can't check my pictures. Hopefully it'll be back and running soon.
The joys of IT! (I work in it, so can say that!)
Postby dursleyman » 15 Jan 2019 17:56
johnnyj wrote:I am a bit confused again. Easily done with me!
Thanks everyone
John, the TR7 does NOT have a voltage stabiliser, but that low fuel delay unit is very often mistaken for a stabilser which looks very similar.
The low fuel light delay unit is usually found fixed on the outside of the instrument cluster which may cause some of the confusion.
See this picture of the low fuel delay unit with its wiring.
I even found a picture of the inside of the delay unit taken by Odd Hedberg.
Image Image Image
johnnyj
Postby johnnyj » 15 Jan 2019 18:35
Russ, thanks so much for taking the trouble to explain that, and for illustrating with photos.
The low fuel delay unit you picture is exactly what I remember, and I really wish I could locate it in my shed! It must be the only part which has gone missing in 20+ years of storage and of course it is the one thing I just cannot locate anywhere. But I have dropped a line to the kind folk at S&S.
Just one oddity. On my car it was 100% located in the engine bay, on the driver's side, corner of the bulkhead (so behind the servo). The wires in the loom are on the outside (engine bay) side of the grommet; there are holes for it in the bulkhead and the wires reach there exactly, plus won't reach the instrument cluster.
Maybe just date-related variations?
Thanks again
Postby dursleyman » 18 Jan 2019 09:50
John,
Just found this picture which shows where the low fuel delay unit was fitted on my DHC when I first got it. The car had been through a complete respray to change the colour. Seems they didn't know where to put it back afterwards!
Its now back where it should be on top of the instrument cluster.
Image Image Image
johnnyj
Postby johnnyj » 18 Jan 2019 19:00
Ha! On mine it certainly goes in the engine bay, but perhaps I should follow suit and put it somewhere novel. I'm thinking attached to a bit of Dexion racking under the rear parcel shelf? :P
In all seriousness, I will certainly double check that I haven't made the wrong assumption about it being in the engine bay. I am sure it goes there but I will "idiot check" in the morning. As an aside, S&S are sending me a used one. Hooray for all the specialists who support our cars.
Thanks again for the info and photos.
All the best
Postby Beans » 20 Jan 2019 14:39
The fuel delay unit is screwed to the top of the instrument binnacle
Just visible to the left of the screw driver’s handle
Postby Rich K » 20 Jan 2019 17:03
Beans is correct as usual. The low fuel delay unit has always been located screwed to the top of the instrument binnacle on all the cars that I have worked on. I have never seen it located either in the engine bay or under the dash.
Rich.
johnnyj
Postby johnnyj » 20 Jan 2019 19:27
Well, I am sure you're both right. I forgot to check today as I was too busy trying to get the headlamp lift motors to work! The R/H one goes up when it should be down, and down when it should be up; and the L/H one doesn't do much at all, really.
RE the fuel delay unit, I'll check again. But here's what I know: by referring to the circuit diagram, I have identified the wires in the loom which go to the delay unit. The colours and combos are an exact match. The four wires pass through a factory grommet on the loom (the same grommet shared with the brake pressure fail switch wiring) and therefore exit engine-bay side. There are two of those plastic captive nut things behind and to the left of the servo, right at the confluence of the R/H inner wing and the bulkhead and almost unseen as they are high up in the corner. And more than anything, I remember it being there. That said, my memory isn't what it was... :)
Postby busheytrader » 20 Jan 2019 22:29
The fuel warning mechanism still works on mine, 2 miles warning before empty :shock:
Postby Beans » 21 Jan 2019 19:00
busheytrader wrote:The fuel warning mechanism still works on mine, 2 miles warning before empty :shock:
Sounds familiar ... at least one thing on 't Kreng that works properly :mrgreen:
Users browsing this forum: No registered users and 35 guests
