Inlet manifold not sealing
mrpatatomoto
Postby mrpatatomoto » 14 Nov 2011 00:20
I hope someone can help solve this problem I'm having, The coolant part of the Inlet manifold into the Head isn't sealing, Its got a brand new O-ring Torqued to spec. But when I put fluid in it comes out between the manifold and the head. Doesn't go into the cylinders thankfully.
Thanks,
Mike
1975 TR7 FHC ACL5526UC
Postby jclay (RIP 2018) » 14 Nov 2011 00:48
The gasket goes on this way:
If you put in on backwards, there is a water hole that is not blocked:
Postby jclay (RIP 2018) » 14 Nov 2011 00:49
It would appear that the o-ring is leaking, but it is water coming out of this hole.
Postby FI Spyder » 14 Nov 2011 00:49
When the inlet manifold is tipped up to get bolted, sometimes the O ring falls out of position. Some use a couple drops of crazy glue to hold it in place until manifold is clamped. The other thing is the O ring the right thickness?
mrpatatomoto
Postby mrpatatomoto » 14 Nov 2011 02:13
The O-ring stays in place, but I was wondering about that smaller hole earlier, Ill check that tomorrow I think the gasket might be backwards. Could be the whole problem. Thank you. I just assumed it was coming out of the bigger hole didn't know where the smaller hole went to.
mrpatatomoto
Postby mrpatatomoto » 14 Nov 2011 02:46
Flipped the gasket around and presto it doesn't leak anymore, Now all I need is some gas and another once over to make sure everything's correct and it should start. Fingers Crossed.
navydiver
Postby navydiver » 11 Dec 2014 16:29
Hey mike do you still have any of the smog parts by any chance?
Rob Cornick
Postby nick » 11 Dec 2014 17:00
<blockquote id="quote"><font size="1" face="Century Gothic, Verdana, Arial, Helvetica" id="quote">quote:<hr height="1" noshade id="quote"><i>Originally posted by navydiver</i>
Rob Cornick
What are you looking for? Please post it on the Parts section of this forum.
'79 TR7 DHC
'76 TR7 FHC
Postby rugbyref1 » 11 Dec 2014 17:49
Rob now owns the car and is busy putting back to original ...
<b> Christopher </b>
Users browsing this forum: Google [Bot] and 52 guests
